BenK
Apr 23, 2017Explorer
Keep looking...they are few, but are out there...look mainly for someone who is into fashion statement and doesn't tow heavy or at all...boulevard cruiser type that wanted a big block
Technology has come a long ways and will continue...more than just the IP for ICE's that has small blocks produce big block levels of power...even pretty good duty cycles at those levels to boot...
But, another component that has made huge MPG strides is the close ratio trannies with DOUBLE OD. That has allowed the ICE's to be tuned to take advantage of closer spaced ratios and that double OD
On my list of things for the day decide to rebuild my K3500 Suburban's 7.4L and 4L80E are a 'built' 7.4L, a 'built' 4L80E (up to 1,000 ft/lb rating, but won't be using it at 1K ft/lbs...so going to have a higher duty cycle) and an GearVendor OD (so it will be similar to newer TV's with double OD). Undecided on lower diff ratios....maybe 4.56 or 4.88 or 5.13 and go with the 0.75 to 0.5 gearvendors
Plus, they have a gear splitter function that will turn the OEM 4 speed into an 8 speed. Key is that mine develops max torque at about 1,800 RPMs and pretty close to that just off idle...so having a double OD will still have my 7.4L in it's sweet range
Here is the 8.1L torque curve, but don't know it will apply to the one you purchase...just a ball park for figuring... More HP & torque than my 7.4L, but very similar shape curves in reference to where it develops torque/hp vs RPM
My 7.4L occasionally (not often, but often enough to claim it) gets 15.x MPG. Mostly 12.x when empty on the highway. 10 MPG when loaded with people and towing 6-8 MPG depending what am towing and terrain
Does NOT consume engine oil till after 3K or more miles....though it beats up engine oil pretty badly and can tell when it is time to change...when the dash gauge drops in PSI
Here is the link to GearVendors and is what am going to get. About $3K, you are buying used, so it WILL still be less than a new TV
GearVendors: CHEVROLET/GMC Truck-Car-Van 2-Wheel Drive 4-Speed Automatics
GearVendors: CHEVROLET/GMC Truck-Car-Van 4-Wheel Drive 4-Speed Automatics
gmcman wrote:
I never understood why GM never offered the duramax as a factory option for the suburban...even if it were to be in small numbers, it would have surely sold.
Well, my 8.1 quest is looking gloomy with all the mpg facts. Even though it would be used sparingly...I'm sure we would use it on occasions and the thought of using 80 gallons of fuel to go to the beach is crazy.....lol.
The 8.1 isn't ruled out, but a 2500 Ram 5.9, pre 08 is looking better. I have friends who see 20 MPG easy at 60 MPH, not towing.... regularly.
What does the Ram 2500 need to be outfitted with for a 10K towing capacity?
