ticki2
Jun 20, 2018Explorer
Grit dog wrote:The rubber washer will also isolate the steel bolt from the aluminum box . It tends to corrode . You also need a locking pin on the mount or the whole shebang could walk .
4 bolts thru the box and the support frame, not the mesh. Put a rubber washer under the bolt head if you’re wanting to keep it afloat.
Or little u bolts if you don’t want to drill the frame on the rack.
44,066 PostsLatest Activity: Jul 25, 2018
