jat4
Jun 21, 2018Explorer
Grit dog wrote:
^Flip the box over, set the rack on it upside down, center it up and drill. Then there’s no holes to line up or layout to do.
That was pretty much my original plan, one problem I realized is the rack isn't exactly flat, there's 1" gap between the box and the rack (or 1/2" on each side of the box resting on the high spot in the center of the rack framing).
So I'm a bit concerned bolts through the bottom may work loose from all the road bouncing. I may loosen the bolts holding the carrier together to see if I can pull it together a bit more square to the box, but I suspect that won't do much.
44,066 PostsLatest Activity: Jul 25, 2018
