Cummins12V98
Jun 11, 2023Explorer III
Lantley wrote:Cummins12V98 wrote:Cummins12V98 wrote:Lantley wrote:
Taking the idea that GVW is a performance and manufacturer's rating only.
Does that mean GVWR doesn't matter and can be ignored?
I don't think so. All the ratings have some significance and should be factored into your decisions.
I never get a good answer on this one.
How can I load my rear axle to it's RAWR of 9,750# and not add a single pound to it's front axle weight of 5,250# and be within the 14k GVWR???
I got booted off IRV.NET over disagreeing with SmokyWren a monitor on this subject.
No one wants to tackle this one??????
If I understand correctly you can't load to the full rear axle rating without exceeding your GVWR.
Much in the same way you can't tow a 15k bumper pull RV without exceeding the hitch rating.
Sure you may be within one rating but exceed others. I'm not sure what's so complicated about that!
What IS complicated is that they have a rear axle rating that you simply can't load to without exceeding the GVWR.
Obviously I don't heed any of this but it is just plain stupid. Here are my last WA State DOT scale numbers.
