sasq40's avatar
sasq40
quick truck camper mounts
hey all, I'm going to look at a camper this weekend and hoping to pick it up. Now my tow truck is down waiting for parts, and I'll be passing through were the camper is with my work truck. I'm looking for some pointers on some quick mounts I can make for my work truck to be able to get the camper home on a 500km highway trip. My work truck is a crew cab long box 2015 gmc 3500. Can i just make a belly bar for the front and rear or do you have any other suggestions?
  • sasq40 wrote:
    im either thinking to make a belly bar out of 1.5 square tubing, mounting it to an existing hole in the frame, and making a rear bar that's inserted into the hitch.
    That's exactly what I did. On the rear, I was able to stick some tubing into the open outboard ends of the transverse tube of the receiver hitch. A little grinding was needed for it to fit. On the front belly bar, there was stuff in the way of putting it in the ideal location, it had to go too far back. So I put a couple ratchet straps from the bumper of the camper to the bumper of the truck to make sure it didn't slide rearward.
    Good luck, I hope it works out!
  • I looked at my camper 750 miles away. It looked like exactly what I wanted. Gave the guy a deposit and told him I'd be back in two weeks with my truck to pick it up. Why not just do that?
  • Take your trailer....the camper MAY be to short for the cab on your truck, so you would have to boost it up to clear anyway.
  • im either thinking to make a belly bar out of 1.5 square tubing, mounting it to an existing hole in the frame, and making a rear bar that's inserted into the hitch. Or my other option is to drive down with my works bobcat trailer and haul it home that way.
