GrandpaKip
Nov 02, 2013Explorer II
I replaced the floor section by the door this summer. From the top, cut out the luaun and foam back to an inch over the I-beam. Put in 2x6 PT in place of the foam with ext. grade plywood on either side screwed and glued together. Took a couple hours. Definitely the sturdiest part of the floor, now.
