Z-Peller
Jul 09, 2020Explorer
campingwiththoreau
Just a thought on a problem I had on my 2002 BF 2500. One of the other outside storage compartments was getting rainwater in it. Problem turned out to be the storage door itself. The doors have 3 or 4 small weep holes drilled in the bottom edge, and the inside galvanized tin lining is caulked where it meets the frame. Seems factory got some of those doors upside down with weep holes in the top of the door. In my case the silicone caulk had mostly peeled off the inside of the galvanized tin and rainwater was coming in through the weep holes and then leaking out of the door into the compartment. I drilled small weep holes into the bottom edge of the door and caulked up the holes on top edge of door. Recaulked the inside rim of the galvanized tin and had no further problems.
44,066 PostsLatest Activity: Apr 15, 2026
