Go_for_Broke
Feb 02, 2020Explorer
Raising TC Off Bed
Newbie here with a question about my first truck camper.
I have read that you can add rubber mat to the floor of the truck bed to raise the TC. This appears primarily to keep the shelf from contacting the roof of the truck.
So far, so good.
I would then assume that some sort of support would be added to the bed rails to support the TC full width.
Here are my questions:
What is a good material?
Should they be the full length of the bed rails?
Should they also span the width of the bed immediately behind the cab?
Should this supports be attached or are they retained by the weight of the TC?
Is a problem with water leaking around and filling the truck bed?
Anything else I should know about this technique?
Thanks Y’all,
So far, so good.
Thanks Y’all,
