PaulJ2
Dec 30, 2013Explorer
john&bet wrote:PaulJ2 wrote:Not a good idea to parallel that small of a wire.
I guess I would just look at the size wire that is there now--probably #12,#14. Then just parallel another say #10,12 back to the hitch. Should give you a lot more current and may be enough.
Not a problem. Two #12's gives you a #6 wire. He already said it is protected with a 30 amp fuse. If one wire should break you are back to your 10 amps again.
44,056 PostsLatest Activity: May 04, 2014
