mdsonofthesouth
Feb 15, 2023Explorer
MFL wrote:
At 33', that would be a chore to handle in the wind, if truck was in stock form. With the upgrades you have, suspension, E-rated tires, I'd sure give it a go. You are an experienced tower already, and should recognize if it handles poorly. Make sure to have your hitch wt at 12-13%, if you aren't overloading your receivers capability.
Welcome to the forum, and good luck!
Jerry
Thank you for your response and welcoming! I do have some experience with 5 or so years with the TT and longer hauling hay but I always appreciate input and can always learn something new.
My guess is the hitch wieght will be between 900 and 1000, but will plan on 1- 1.1k hence the idea of going up a size with the wd hitch. My max weight for my hitch is 1200 which is also a concern, but within spec. I have alot of thinking to do that's for sure!
44,072 PostsLatest Activity: Aug 30, 2026
