mdsonofthesouth
Feb 16, 2023Explorer
Thank you to all those who responded. My confidence went from on the fence to uneasy to downright against the idea. The numbers "work" but I need to feel better and there just isn't enough margin in the numbers to make me feel comfortable and possibly risk my job or legal troubles.
Thanks again, but for now I am moving on. My new plan is to limp the current TT and maybe remodel the inside on the cheap and work at getting the next tow vehicle as soon as I can. Once I have the neext vehicle there will be no need for a question like this lol. Yall stay safe out there!
Well as I stated my comfort level has lowered with the idea and I am now certain Im not going through with it. If I were to for a short period the bed would HAVE to be emtpy for it to work.
No reason other than laziness while being super busy with everything else. Honestly I should have gone with my gut before even posting which is to stay at 80% or lower for payload and towing. I got ambitious since the numbers "fit" and the size was the only alarm bell I was paying attention to. Add in that we NEED more space and needing more repairs that will be costly and the blinders were thick!
As for a new tow vehicle right now is an absurd period of time but I doubt the prices will adjust terribly much as people are still paying them. Sure repos are up and sales are down, but I think manufacturers are still getting enough to keep things the way they are or close to it.
APT wrote:
Do not recommend.
I can show math that shows that you will probably exceed rear axle rating, GVWR, and maybe receiver rating. 7200 pounds dry, 8500 pounds loaded 1100 pounds of TW, family onboard and a bed full of camping gear, etc.
I can summarize the feedback from RV.net of owners that typically tow 8500 pounds with half ton trucks - not many are comfortable at 65mph. Light steering, wandering, wind and passing wind impacts.
The modifications you have made will improve the comfort level at or above any of the ratings I mentioned above, but that is hard to quantify. So that is a risk that is difficult for any of us to uniquely confirm with your exact combo of vehicle, trailer, WHD + adjustments, loading.
bikendan wrote:
mdson, is there a reason you haven't posted your actual door sticker payload capacity?
I'm in the same place as you. The DW wants a particular TT to replace our current TT. I'm up against similar numbers and have a F150 Ecoboost with Max Tow package.
It's 29ft long but is about 2000lbs heavier than the 25ft TT we have.
I'd like to upgrade to a 3/4 ton but now isn't a good time for that.
44,072 PostsLatest Activity: Aug 30, 2026
