HP is a measure of how much torque an engine is producing at a certain RPM. Below 3500 RPM the diesel is making more HP than the Hemi. Above 3500 RPM the Hemi makes more HP. In the same gear, below 3500 RPM, the diesel will put more torque to the ground than the Hemi.
Yes, of course. But I'm saying this isn't a terribly meaningful comparison, because when power is needed on the road, they won't be in the same gear. Gear selection is a critical part of putting power to the road. Why would anyone select a gear that doesn't provide the needed power?
The two vehicles will drive very differently and because most driving is done at engine speeds below 3500 RPM, many will find the diesel more satisfying to drive, even though it isn't capable of the same all out performance.
I'd agree that's true of those with downshiftaphobia, yes. But while most driving is below 3500 RPM, it's also true that most driving doesn't require a lot of power. The real difference surfaces when that extra power is needed. One drivetrain can downshift to get it, the other can't.
wilber1 wrote:
No one would argue that the diesel is the more powerful of the two....
I wrote:
I assume you mis-typed here. If not, then I would argue.
wilber1 wrote:
Read it again.
I did read it again. The 3.0L diesel makes 240 hp, the 5.7L Hemi makes 395 hp. I acknowledge that power doesn't exist across the entire RPM range, but it's just not accurate to say the diesel is the more powerful of the two.
-- Rob
