Turtle n Peeps wrote:
I'd like to see real-world tests run at no more than 4000 rpms or so.
Why? Why not run the engine up to where the engine makes it's rated power? People really need to get over their fright of high RPM's. If they don't like high RPM then the only alternative is a supercharged engine where it gets it's air in early or a diesel engine.
The problem with modern computer control engines is they can pull power out at any time they want.
These high power hot rod engines have a very low duty cycle. Sure, they make big HP but then they will pull power to keep from melting down.
Yeah, you're not the first that's said that, and I agree that these engines are designed to rev. But as you mentioned it's about duty cycle; I'm not so much interested in brief acceleration but rather constant output for hill climbing. I've often had to drop to 2nd and rev to 4500 rpm to maintain a reasonable speed (50-55) for extended periods of time. Not only is that not comfortable, but I think that has to have an effect on the longevity of the engine.
So a tow rating is one thing, but how well it does it is another. I will watch the videos tonight, but in the past I've tried to have a 20 percent margin, but I wondered if the diesel didn't really need that margin.
