chadsdad01's avatar
chadsdad01
Ram 1500 towing
If you tow with a Ram 1500, please tell me how the truck is configured, and what you are towing. Please only reply if you are doing this or have done it personally.
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    2008 5.7 QC, 4x2, 3.92. Last scale ticket was 7,860. Normally somewhere between there and 8k.
  • 2015 Ram 1500 Ecodiesel towing a Roo 183. Hitched up with a Reese Dual Cam. Now that I have the truck, I want to upgrade.
  • I tow a 25 foot 5000, pound (empty) Pioneer with my 2014 Ram with the V-8. Full it is probably 6500 pounds
    It tows it much better then my old Ford F-150.
    It will tow at any speed you want to go, and many times I forget the trailer is behind me.
    I live in the steep NC mountains and it pulls up them at any speed I want to go. I can go up them at 50 miles per hour where as my old F-150 would be held to 35.
    My only complaint is downshifting coming down steep mountains it will not hold back without going into high RPMs.(that is both in tow haul and out of tow haul)
    My gas mileage average at 65 is between 12 and 13 MPG. If I am at 70 or 75 it drops to 10. That is with the bed fully loaded and tw0 long sea kayaks and a canoe on the roof.( I have a cap on the bed)
    So far we are on our second 2000 mile trip with it
    If I had to get another truck today I would get the same
    Jack L
  • Don't really know the full question. We have a 2004, using Hensley and the trailer listed.
    Tows great.
    I'll keep following this to see where it goes
  • 2013 quad, 4x4, 5.7, 3.92 :)
    Tows my tiny 20ft 3500 lb kz tt beautifully. No problem for lack of power, easily passing much bigger trucks towing much larger trailers up steep grades.
    Only negative, the coil springs sag as I reach max payload. Sumo spring helpers worked wonders.
    I use a plain ball hitch and occasionally a friction bar for anti sway.
  • I tow with a 2009 Ram 1500 with quad cab and 3.92 rear end and 5.7L Hemi. My trailer gross weight is 7,800 lbs. Been in the Rocky Mountains many times with no problems pulling. Just the wife and I.
  • I have a 2011 with the 5.7 V8. It is the quadcab and we tow a 2003 Coachmen Cascade 25RKS and recently changed to an Andersen WD hitch, a good move. Very happy with the vehicle and performance.
    We have now put above 10,000 miles of towing on the truck and find no fault with it.
