bighatnohorse wrote:
When I started looking at the Dodge and Ford diesel forums there was one consistent problem that persisted right up to 2015's
The problem had nothing to do with the engine or transmission.
And while the depth and breadth of knowledge on the truck camper forum is extensive, it surprises me that the one persistent problem which you will have to address with an older truck has not been addressed.
Research thoroughly.
Is this like 20 questions or you want to give the OP some advice? If you do, maybe you'd care to share.....
Ok, then spoon-fed: http://www.classaction.org/dodge-ram
This is a well know problem but not the end of world sort
Google thusly: 2015 dodge death wobble
Btw, I got 135k on my 07 Dudge on original front end components. Good tire wear still and no dw. I did have an 09 F350 work truck for a bit that got the shakes at like 25k mi!
Seriously though it's just maintenance and luck of the draw. Every solid axle vehicle is suceptible. Relatively new 4 door Rubicon on OE tires got it once heading up hunting. Had it happen in multiple old trucks back in the day.
But that's a good reason not to buy those trucks........
