Ductape
Apr 14, 2015Explorer
Me Again wrote:Ductape wrote:
FCA knew that truck had the ratio before it was delivered. Without the correct ratio in the PCM the vehicle goes into limp mode right away. All the wheel speed and trans sensors must agree on RPM or else no go.
And you know this because? The larger RAM's get speed from a differential sensor and gears can be change without effecting anything else. Chris
One thing that can always be counted on with this forum is as soon as anyone says "left" someone else will post "right". Ordinarily I ignore it, but just in case any readers care about the facts:
Part # 68231044AA is the rear wheel speed sensor for a 2014 Ram 1500; it uses 2. One for the left wheel and one for the right...
So I can ask why you don't know this? Can you show us the part number for the sensor you believe is in the diff?
Just because something was true in older vehicles does not make it true now.
44,060 PostsLatest Activity: Mar 28, 2026
