djcjc's avatar
djcjc
Ram 2021 questions
Going to get a new Ram Have a 2012 3500 Dually going to go to a 3500 crew cab 8 ft bed SRW, is the HO worth the 3 thousand upgrade over the standard cummins. I have the high output on my dually but torque is 800 # so is it worth it or not. Also have a 4:10 rear end on existing but thinking 3.73 on new one would like a little better mileage when not towing. Have loved the dually for pulling our 36 ft TT but going to go to a fifth wheel and not anything huge usually just me and wife with grandkids visiting some times. SRW will make daily driving a little easier.
  • That's a good question. Even the standard engine has big power. I'd say you definitely don't NEED it but sure would be nice.
    --> Have a 2012 3500 Dually
    --> going to go to a 3500 crew cab 8 ft bed SRW
    --> I have the high output on my dually but torque is 800 # so is the HO worth the 3 thousand upgrade over the standard cummins
    --> going to go to a fifth wheel and not anything huge
    --> SRW will make daily driving a little easier.
    The truck you want to buy is nearly identical to my 2014 crew cab, long bed 2500. My Cummins is 370HP/800TQ with the 68RFE transmission. I pulled a 14,000lbs 5er through the Rockies just fine and never felt overmatched by the trailer. I've also pulled gooseneck trailers in the 15,000lbs range and it handled that very well. The OEM engine brake is out of this world for towing :B
    Is the HO upgrade worth it? The extra 275 ft-lbs of torque is nice and the Aisin transmission is more stout than the 68RFE. Is it $3K better, I'm not sure because the standard 385HP/850TQ is a pretty good package. Also, I don't know if you can get the HO package in the SRW 3500.
    Absolute #1 thing for sure: Get the factory 5th wheel and goose neck prep packages! It's only something like a $500 option and worth it's weight in gold. This setup makes install and removal of the 5th wheel hitch a breeze. Plus your in-bed wiring is already done as well.
    The optional camera package is really nice. I've driven the newer trucks that have the bed view camera and it makes lining up your 5er pin really easy. Obviously you can do this without the camera, but man it makes things so simple and eliminates those 2 or 3 trips in and out of the cab to check alignment.
    One final suggestion. If you get a 4X4, order the OEM side steps. These trucks set really tall and unless you have some long legs it's a real stretch up into the cab without the side steps. My truck had aftermarket steps when I bought it and I had to replace them. I went with OEM and they are so much firmer and solid feeling than the aftermarket ones.
    The SRW crew cab long bed truck is definitely narrower than the dually, but it's still a land yacht. Easier to drive for sure than the dually, but you still need to plan your turns and watch your mirrors because these dudes are looooooong
    KJ
