Huntindog
Sep 14, 2014Explorer
AH64ID wrote:Huntindog wrote:
2008 to 2014. BIG difference.
Nuff said.
Not really, how about a little research.
The rear suspension and tire arrangements are the same. The frame is different, but there just isn't that much frame flex on a heavily loaded Dodge/Ram.
The front suspension is completely different, but that has no effect on DRW vs SRW so not valid and will only help make the '14 SRW better than the '08 (03-12 FWIW) DRW.
nuff said
OK some research then.
Dodge certainly sees it differently than you do.
They rate the 2014s wayyyy higher..
Perhaps you should get a job with Dodge as you seem to know more than they do.
