towpro
Sep 24, 2015Explorer
the frame mounted spring perches on my 2015 DRW Ram appear to be welded on.
but even if you could weld them on the SRW truck, you would probably need to also add that long that hits the spring perch with load.
I think we need a better name than "overload spring" because its not really overloaded when they start to work, its a way to use softer springs for empty ride, but give weight carrying capacity when heavy load lowers the truck to the point of spring contact.
