Rangerman40 wrote:
It's a 2015 3500 DRW. Payload if I remember correctly is 58xx.
And before someone asks.... It's a MegaCab which is why the payload is so low for a DRW.
Payload is 5,800# or so and even at 16,000# GVWR for the 5er is 3,200# well under the Max Payload of the TV, Look at the yellow sticker, that is tire PSI for MAX payload, if it shows 65 pst you might look at running the rears at 55 to 60 psi and the fronts at 65 psi.
Look at the tire side wall an what is the MAX weight rating at 80 psi? Keep in mind you have four tires supporting that weight, if your empty rear axles weight is even 3,500# and the pin is 3,200# total is 6,700#. That means 6,700# / 4 = 1,675# per tire, so even de-rated to 2,500# per tire dual each tire is carrying 900# LESS than rated for at 80 psi, making the tire over inflated for the load carried.
At 80 psi inflation with the assumed load your tires look like the profile on the right side of the picture.
