Hiking_Hunter
Jan 07, 2018Explorer
Greene728 wrote:
Truck in my sig has the 3:42.
Fuel mileage is 16.5–18 normal every day driving, and seen 20-22 on interstate just cruising at 70ish.
Towing it’s worst has been 10.2 and best of 11.8. All mpg numbers are fully stock.
Lock out 6th gear, engage EB and TH and it’s a pulling beast.
Same here - 2013 model SRW, same rear end. Dragging 11,800 lbs. I get 11.5 to 12.2 mpg. I also lock out 6th unless I'm in the flatlands. Love the exhaust brake. No regrets for me on the SRW, however, if you think there's a chance you will ever be pulling a camper that requires the extra pin weight capacity then go with the dually.
44,070 PostsLatest Activity: Jul 11, 2026
