IdaD wrote:
Your truck is rated to carry a whopping 500 lbs more on the rear axle than the truck OP bought. Yay.
You ought to buy a DRW or better yet a MDT/HDT if you want to tie your masculinity into what you drive.
Did I miss a post where OP said he bought a truck? On edit: I see he said he will be signing for a 2500. And yes we all know that you think your coil strung 2500 is just as capable as a 3500 SRW.
I thought the same about my 2001.5 2500 with the camper option, which just happen to have a similar rear spring pack to the 3500's that year. RAM has gone back and forth on several different rear leaf spring setups between the 2500 and 3500 SRW, until 2013/14 when the 2500 got a completely different rear with coils. Why did they not carry the coils over to the 3500 SRW?
