Me Again wrote:
IdaD wrote:
I'm not bitter in the least. It's just baffling how overblown the difference is with some on this board. I can't tell if it's willful or just plain ignorant. Probably some of both.
Again, if the coils are so effective at a good ride and load carrying why did RAM not use it on the 3500 SRW.
I have an answer that would apply for many. Lets see if you can come up with the same answer?
Chris
The coils give a better ride. Plain and simple, and they're rated correspondingly lower. A whopping 500 lbs lower. Probably not much more than an average rv.net wife. That's the stock versus stock difference. Do I think the Timbrens I put on my truck that are rated to carry 8600 lbs
more than make up for that 500 lb lower stock rating? Yep. Again, if you want to tie what you drive to your own sense of masculinity you should have bought a dually or more and actually stepped up.
