Greene728 wrote:
IdaD wrote:
Me Again wrote:
IdaD wrote:
I'm not bitter in the least. It's just baffling how overblown the difference is with some on this board. I can't tell if it's willful or just plain ignorant. Probably some of both.
Again, if the coils are so effective at a good ride and load carrying why did RAM not use it on the 3500 SRW.
I have an answer that would apply for many. Lets see if you can come up with the same answer?
Chris
The coils give a better ride. Plain and simple, and they're rated correspondingly lower. A whopping 500 lbs lower. Probably not much more than an average rv.net wife. That's the stock versus stock difference. Do I think the Timbrens I put on my truck that are rated to carry 8600 lbs more than make up for that 500 lb lower stock rating? Yep. Again, if you want to tie what you drive to your own sense of masculinity you should have bought a dually or more and actually stepped up.
Are you not the one CONSTANTLY trying too defend your 2500 to a 3500???
Again, envy much?
The vast, vast majority favor the 3500 to the 2500 towing. Especially 5th wheels.
Its OK you need a band aid to do what the 3500 does in stock form.
I don't need timbrens. Lol
You need to leave rv.net and go out in the real world. And I don't envy a thing, I just take issue when folks on here repeatedly state falsehoods over and over and display that ^^ kind of attitude. I should just ignore it because it isn't important, but it irritates me.
