towpro wrote:
lots of replies on here have never seen the ram air suspension.
its doing what its supposed to do. I have never owned one personally. I have heard some don't like it because the air bags allow the transfer of air from one bag to the other which can allow more sway.
I know Hellwig Products released a sway bar for the factory air suspension. (and I have had to add a sway bar to every Ram 3500 dually I have owned for pickup camper usage)
I think you also have an alternative ride height selection that will lower the truck 1" which might bring that lower spring into play loaded.
Have you seen one and understand it? Im almost certain the bags aren't plumbed together, that would be a horrible condition. Each side wouldn't be able to level up separately if that was the case.
Bigger sway bar always helps with a TC.
And OP isn't in the question answering mood, as he's responded to this thread since I asked the same question. Also surmising he isn't in alt load ht and hasn't actually driven the truck with the camper on.
But again, ICBW, as some just aren't good communicators even when asking for assistance.
