SoonDockin's avatar
SoonDockin
Explorer II
May 02, 2023
Ram 5500 Front End Alignment Issue
My new 2022 Ram 5500 has never felt like its aligned properly. The steering wheel is canted to the right a bit. I have called three ram dealers, two of which sell commercial trucks. None have a rack big enough to align a 5500. This is in Oklahoma. Anyone know of a decent repair center around here that can align a new 4x4 Ram 5500?
  • I have been to two dealers that will do a 3500 but not a 5500. Say their rack is not big enough. Might be because mine is a chassis cab with slightly longer wheelbase. My biggest complaint is it wanders a bit. The wheel has a bit of slop and it takes a lot of concentration to keep it between the lines. Not dangerous just annoying. I have less than 3000 miles on it and no sign of uneven wear yet.
    I could live with the wheel off center if it drove with authority. But that's not the case.
  • JRscooby wrote:
    Don't know where in Ok you are, but it is not rocket surgery. Document the dealers can't/won't do the work. Look for any real truck dealer. (KW, FL, IHC, Pete, Volvo) Sure, you will have to go into your pocket, but get a 4 wheel alignment. Maybe if you can show you had problems from jump you might get repaid.
    4 wheel alignment? Lol :S
  • Cummins12V98 wrote:
    You don't even need a rack to center the steering wheel. Any simple minded mechanic can adjust it. This has nothing to do with an alignment rack.
    While this statement is true, I think that unless a simple minded mechanic has already worked on it, there might be other issues. After all a simple minded factory worker put it together, and a simple minded dealership mechanic did a pre-delivery check on it.
    This is why I say take it to a shop for complete inspection, like they do before they put it on the rack for 4 wheel alignment.
  • You don't even need a rack to center the steering wheel. Any simple minded mechanic can adjust it. This has nothing to do with an alignment rack.
  • If their rack will accommodate a 3500, they can do the 5500
  • Don't know where in Ok you are, but it is not rocket surgery. Document the dealers can't/won't do the work. Look for any real truck dealer. (KW, FL, IHC, Pete, Volvo) Sure, you will have to go into your pocket, but get a 4 wheel alignment. Maybe if you can show you had problems from jump you might get repaid.
  • Unless you’re trying to get warranty idk why you’d take it to a dealer. Go to a commercial tire shop.
    But does it pull left or just the steering wheel off? And are the tires wearing like it has an issue?
    There’s a difference.
    If the wheel is just off center and it’s otherwise aligned (which you allude to) then I wouldn’t get it aligned anyway. But you could adjust the steering arm a smidge the other way to center the wheel.
