Perrysburg_Dodg
Mar 01, 2017Explorer
fulltimedaniel wrote:
Well my Owners manual says no such thing. Yours could be a later edition where it could have been corrected. Mine is a First Edition.
As for being "harsh" on Ram. I dont think I was. The dealer does not build the truck nor do they write the owners manual nor do they decide what is optional. Nor do they spec what Cummins puts in the engine. This was clearly a Manufacturer issue.
LOL sorry the manufacture does not order the truck the dealer does and the know nothing sales manager specs out what he thinks the customer wants. ALL Ram diesel come with the block heater installed from the 3.0 Eco diesel to the 6.7 Cummins they have the heater installed when the engine is built. Otherwise you would have to knock out a soft plug to install the block heater and then replace the coolant.
If you bought a in-stock until or dealer ordered unit they did not order the "COLD WEATHER GROUP" as other have said. If you went to the dealer and ordered the truck BOTH you and the dealer forgot to order the aforementioned group. Just buy the Mopar cord off Amazon or E-Bay, that way the mounting clips will be on the plug to secure it to the frame and enjoy your truck.
I would bet dimes for dollars that both Ford and GM build their diesels with the block heater already installed for the reasons I stated above. Unless you are going to be in -30* weather you don't need the block heater. My truck sits out side and has never been plugged in. Turn the key on, wait for the grid heater light to go out and start the truck. Let it run a few minutes (I go 5-10 depending on temps) and drive off. Do not hot rod it until the truck is up to full temp.
Don
