Perrysburg_Dodg
Mar 04, 2017Explorer
Lynnmor wrote:Perrysburg Dodgeboy wrote:
As far as the oil, the heaters only heat up the anti-freeze and not all of it unless you have it plugged in all night. The oil is all in the pan, I do not think any heat from the block will get to the oil. It will help keep the upper half and pistons warm to add in starting along with adding heat well some heat to help with defrosting the windows.
Actually cold oil flowing thru the warmer block and head will warm up on contact.
???OK how does oil flow when the truck is not running? We are talking about basically a hot water element warming up the coolant and basically only on the right side of the block. Yes as the water warms up it will warm the rest of the anti-freeze up but only if you have it plugged in long enough. The oil is going to be cold on start up even if the truck in plugged in.
Don
