ib516's avatar
ib516
Explorer II
Dec 12, 2017
Ram Cummins Vs GM Duramax Ike Gauntlet
VIDEO
My summary:
- they both can tow 12.5k lbs anywhere, even in the toughest conditions, with ease.
- the Duramax exhaust brake works too good?
- the GM's hitch is heavily reinforced and you may need to rig up something for the safety chains to easily attach if you bumper tow.
- buy the one you like from a dealer you trust will look after you if there are ever any problems.
  • Cummins12V98 wrote:
    How about choosing a gear like 3rd or 4th and set the cruise to the speed you want to hold. Works GREAT!
    I have tried the AUTO mode, the above works MUCH better! Maybe it has to do with me towing 6% or steeper grades with a combined 33-35K.
    Well here lies the problem. THEY DON'T MANUALLY SHIFT THE TRUCKS IN THESE TESTS!!!!
    I am not saying that regular mode does not work the best, and it does work the best if you manually shift it. However, if they want the truck to do all the work(like they do in these tests) then auto mode is the mode they need to be in.
  • How about choosing a gear like 3rd or 4th and set the cruise to the speed you want to hold. Works GREAT!
  • eHoefler wrote:
    They ran the GMC in tow/haul, and didn't in the Ram.
    This is true going uphill, BUT downhill they DID.
    Using the Lie O Meter is a joke.
  • I think every Cummins owner here needs to write these guys an email telling that they need to use the exhaust brake in auto mode(green icon) if they are going to let the truck do all the work and in regular mode(yellow icon) if they are going to manually shift.
  • Why would anyone leave the exhaust brake on long enough to slow the combo way below the speed they want to travel at ob down grades. Maybe I missed somethin'.
    Anyways good for GM and a EB that works like it should.
