ib516 wrote:
I agree, they RPM "data" is useless unless we know the camera was on the gauges when the trucks were on the same spot on the hill. The grade varies.
As I stated in my initial post regarding this, I was just going based on the limited screen shots we had and the knowledge of how much rpms play a role in fuel economy when I was at Cummins.
The same logic is applied to why taller rear gears gains better fuel economy because they keep you at a lower rpm. However, in this case due to the Ford and Ram having taller rear gears, they ended up having shorter final ratio due to being in 4th versus 5th in the GM
With this, it should be a no brainer that the GM truck had the best fuel since it was at 1,600 rpm in 5th giving it a combined final ratio(5th gear+rear gear) of 2.65:1. The Ram was second best hovering around 2,050 rpm in 4th with a final drive ratio(4th gear+rear gear) of 3.42:1. Then the Ford in third being at 2,500 in 4th with a final drive ratio(4th gear+rear gear) of 4.05:1. More rpms means more injection events per minute so if each engine is at 100% load, then the one with least injection events or volume per event(which should be very close with these engines with the Cummins having the slight advantage) will burn the least amount of fuel.
Also, as TnP stated earlier,a heavier or lighter load might have changed the outcome. So would a higher or lower speed. If they would have lowered the speed to 55 mph and forced the GM to downshift to 4th as well then the Ram would have had the least rpms and tallest final ratio. If they would have increased the speed to 65 mph allowing the Ram to have enough rpms to shift into 5th then the Ram and GM would both be hovering around 1,800 rpms and very close final drive ratios. This is assuming that each were making enough power to drive at these speeds with that load. From the videos, it is clear that they do.
