- Grit_dogNavigator III
cummins2014 wrote:
Grit dog wrote:
Cummins12V98 wrote:
dodge guy wrote:
I work at a dealer an I’ve only seen one Aisin failure. I see far more emmisions failures than anything, DPF, sensors, etc!
Before I bought the MH I was looking for a 6.4 gas truck specifically to get away from an issue while on the road.
You are SPOT ON!!! I personally know a Top Mechanic and the Parts Manager at my local Dealer, they say the same.
So YOU had the only Aisin failure in your dealers history? Lol
Very ironic…
Lol , and you know they are all telling the truth, that's amazing only one failure per dealership. :B
Lol and after your recent dealer experience (on CF.com) you have the most reason to be skeptical! That was some next level stuff! Cummins12V98 wrote:
"hot shots all run Dodge/Ram cummins because they're the best"
Here we go again!!! NEVER said "ALL" I have said most. NEVER said they were the "BEST".
Must be fun putting words in peoples mouth. Seems like truth will net you more credibility.
Bottom line is this hotshot owner has a lot of experience with Ram trucks so thought this would be more credible as your response would be predictable.- Cummins12V98Explorer III"hot shots all run Dodge/Ram cummins because they're the best"
Must be fun putting words in peoples mouth. Seems like truth will net you more credibility. - Cummins12V98Explorer III
Very ironic…
Never said that, you need to keep track of my posts like "FISH" does. I did say they had two I believe. They replaced both trans no question as they had bad castings causing internal bleeding if I remember correctly.
Truth!!!!!! Is my trans did NOT fail from any issue with the trans. Mechanic did not follow proper seperation and assembly to replace weeping gasket. So again you need to keep files of what I have said like "FISH" does. :B - Grit_dogNavigator III^Right? Lol
I don’t darken dealer service bay doorsteps very often, but having had a couple dozen new trucks in the last couple dozen years, I get to sometimes unfortunately.
And they’ve “never seen this issue” more often than not. Hahaha - cummins2014Explorer
Very ironic…
Lol , and you know they are all telling the truth, that's amazing only one failure per dealership. :B - dodge_guyExplorer II
Very ironic…
Not me, the dealer. And seeing as how we do a lot of the HD trucks you would think with them having a higher than normal failure, we would see alot. We don’t! And we do alot of hotshot trucks. - Grit_dogNavigator III^ Funny thing is, as soon as that video was finished, the next one auto loading was “2022 7.3 Godzilla. Don’t buy one, you’ll regret it”. Lol
Grit dog wrote:
FishOnOne wrote:
2020 with a lifter/s failure... China bomb lifters!
Link
Throwin out new bait…hoping to hook another fish….lol
Cummins12V always reported that hot shots all run Dodge/Ram cummins because they're the best, so with that in mind; I'm sharing a hot shots experience with his fleet of new Ram cummins trucks.- Grit_dogNavigator III
Very ironic…
44,056 PostsLatest Activity: May 04, 2014
