transamz9
Dec 19, 2014Explorer
mich800 wrote:
I always find it amusing when this video comes up. You can tell the Ram is pulled far enough forward where only the right rear is unloaded. The Ford is teetering on the right front and left rear. It is obvious when they pull down on the Ford and it rocks pivoting on the balance point. The Ram does not come down because there is too much weight on the left front (it is not balancing on the two tires like the Ford)
So what you are saying is that if they would pull the Ford forward far enough that the left front would be on the ground more that the frame wouldn't flex? :S Both trucks had the weight of the RR off the ground. The Ram is holding it's weight the Ford is not. Simple as that.
