CampingN_C_
Nov 04, 2015Explorer
spoon059 wrote:CampingN.C. wrote:
So if the road required 1st gear, TC won't lock in first gear and the EB doesn't work at all in 1st or with the TC unlocked. What should I have done different?
You have to get up to either 3rd or 4th gear and above 1100 RPMs to engage the exhaust brake. Once the exhaust brake is engaged, it will continue to give braking power all the way through to 2nd gear, so long as the RPMs stay above 1100.
To answer your question, you would have needed to get into 3rd or 4th gear, with tow haul on and the EB on to activate braking and allowed the exhaust braking to scrub your speed. Then you could have manually selected your gear and allowed the EB and gears to hold you at a constant speed.
Without going through the process, its not going to work. That is the nature of the beast.
That may be it then, I never did any of that. I never got faster than maybe 30-35mph after turning it on. In fact, now that I think about it, I switched it from 'full' to back to 'auto' at the top of the hill, which basically reset it. Sounds like that's where I screwed up. But, it's not exactly like I could speed up just to allow the EB to activate.
