Grit_dog
Nov 06, 2015Trailblazer
NC Hauler wrote:Grit dog wrote:
The one guy had the right idea, get er in 4 low if you have to then you can work the upper gears at higher rpms. BUT if you're on twisty pavement that requires going that slow then you're making prety sharp turns. Get ready for the front axle to buck in 4wd.
That's the beauty of having locking hubs which no one offers anymore (no, Fords don't disconnect either. Basically the hub locks are a sales gimmick). You get 2wd low range.
For those that still don't understand why the factory turbo brakes don't engage in 1st gear, is the trans always slips in first gear, doesn't lock up the TC. That's where the last of the hand shakers shines because you can use a retarder in first gear.
I've never felt the need to put my truck in 4 wheel high, much less,4 wheel low when towing on type terrain we've been dicussing here.:h
My tranny is still slowing truck when it downshifts to 1st gear,and will continue to slow it.
Me either, on dry pavement, but the op apparently couldn't hold his load LOL, with the jake brake and service brakes at his speed and gear, so..........
Btw, you won't hurt a thing running in 4 wd on dry pavement.
I've driven and towed many thousands of miles in 4wd. Granted most was snow but dry stretches didn't blow up the truck.
Personally I would just not point my big 5ver down a twisty grade like that if the truck struggled to hold back the load.
