Perrysburg Dodgeboy wrote:
Everyone knows that a in-line engine makes tons of torque down low and thru the mid rpm range and a V8 is just the opposite so the V8 should be able to out run the Ram over a long haul.
False! I am starting to not take you seriously on how much false information you have posted in this thread. There are many characteristics of an engine that determines when it gets its power, but the cylinder configuration is NOT one of them. The stroke length of the engine has a lot more to do with when an engine gets its torque. There are a lot more dynamics in an engines design that effect its characteristics as well. Currently all three light heavy duty diesel engines get their peak torque at 1,600 rpm. The only odd man out its the Cummins high output variant that gets its peak torque at a higher 1,700 rpm.
Here is some light reading with the actual differences between a I6 and V8 diesel.
I6 versus V8 diesel.Perrysburg Dodgeboy wrote:
As far as the lying about the SAE J2807 specs both GM/Chevy and Ford had to remove parts and not just on the F-450 but all across the line up, to be able to get their trucks to look half way decent, Ram did not!
Don
False! Not the F150.
As far as the 2.7L EB versus the Ecodiesel, the mpg may be different but the cost per mile may not be too far off depending on the time of year due to the cost difference in fuels. Also the 2.7L was not "racing" up the hill since it was just doing the speed limit and had plenty of power to accelerate if needed. Just because the Ecodiesel could not hold the speed limit and the Ecoboost could does not mean it was "racing" up the hill. The quicker (not faster) off the line acceleration of the Ecodiesel has a lot more to do with the muck lower first gear of the 8 speed in the Ram than it had to do with engine power.
The differences between the two just depends on preferences. If you like having power to spare in those cases when you need to pass traffic that is going slower than the speed limit and do not mind paying extra in fuel then the 2.7L Ecoboost is for you. If you want better fuel economy, but do not mind not having as much power or you do not mind going slower than the speed limit then the Ecodiesel is for you.
My preferences is that I don't mind paying more for power and capabilities. I have been in one of those situations towing where I was stuck behind slower moving traffic back when I had my 4.6L. I could not pass because I did not have enough power to pass without needing two miles of roadway to do so since the truck was barely able to accelerate. The semi in front of me and I were being passed by trucks that had more power than mine and I was stuck behind that truck for at least 20 miles. After that I said never again which is why my trucks have always been overpowered since then, and I will gladly pay extra for it. Others may not feel the same.
