wilber1 wrote:
A lot of vehicles have torque management. It's called traction control.
False! Torque management is NOT traction control. Torque management is the ECM cutting the power of the engine between shifts and in low rpms to save the transmission and driveline. With diesels, the ECM will lower boost levels and fuel delivery to manage the amount of torque going through the driveline. Traction control is something totally different and is used for totally different reasons.
Also to everyone else, a lot what most perceive as torque management is actually the laggy and slow to respond pedal in DBW(Drive By Wire systems). Just because one mashes there pedal down does not mean they are sending telling the engine to give you 100% power. The DBW sends a signal to the ECM and the ECM will dictate how much power for the engine to give. One may press their pedal down 50%, but the ECM is telling the engine to only be at 25%. There are ways to get around this like the BD throttle sensitivity booster. Of course not all of it is the pedal and a tuner will go the rest of the way in taking off torque management or force the engine to not lower boost or fuel at lower rpms and between shifts.
