ShinerBock wrote:
Still waiting? Where did I say I will show you evidence in the first place. I went back though out our conversation and didn't see a single point where I said this so i am not sure what your are seeing. However, if you want to go down that road, I can say the same to you to provide evidence of what you say is fact. You can't just as much as I can't.
You stated a 200hp version doesn't result in any increase in durability. When you make a statement, be ready to defend it. And no, "I worked in the industry" is not a defense - rather, it's lack of defense.
Tech jargon? B10 and B50 percentages are what is used in the manufacturing world to measure an engines reliability given certain variables. If you are discussing an engines reliability under certain conditions or load(which we are) then they apply. I am sure that using Google to look up "what is B10 engine life" to know what I referring to
Do you always give lectures thinking no one knows as much as you?
Re-read what I said - saying B10 AND B50 together, is redundant. In this context, if B10 goes up/down, then obviously B50 does as well.
Hold on. let me go back......Nope, not once did you ask to back up anything so that statement is false. Again, of you want to go down that road then I can and will ask you to back up your statements and you will not be able to as well since they are based on theory and not fact.
Here's my reasoning - I hope you agree an engine at cruise, making 50hp will last longer, in hours, than an engine at WOT redline, correct? I don't think I need to prove this one - it's basic powertrain engineering 101.
The 200 hp engine is essentially a 300 hp engine at 66% throttle. Factoring emissions and thermal constraints, the engine at 200hp may experience even less than 66% of the thermal/mechanical stress.
So logically, how does the 200 hp engine NOT last longer?
No, I don't totally agree. Because just like the video link I posted stated, a restricted VG turbo has more drive pressure(back pressure) than a a correctly fixed FG turbo even with the same compressor size. The reason for higher EGT's is because their is not enough air for the amount of fuel being injected which is generally due to the VG turbos restrictive turbine side, not compressor side. A turbo with a higher CFM will reduce EGT's at the same load and will also require lest boost pressure t achieve the same power output.
However, stock VG turbo's are used primarily for emissions purposes even though their high drive pressures and EGT's reduce the reliability of the engine. In instances where the Cummins 6.7L does not have to meet such strict emissions requirements, a fixed geometry turbo is used like the one on e the marine 6.7L that achieves 550 hp and 1,250 lb-ft.
You also do not know what the internals of these engines can handle and I have seen what they can reliably. If an engine's internals can handle say 800 hp reliably due to its design and build quality, then putting 550 hp versus 200 hp will have no effect on these internals. This is what I am trying to tell you by talking about the turbo. It and the amount of pressure and volume from the HPFP is the limiting factor in reliability at higher power power numbers while also meeting emissions. The internals can reliably handle way more than what these two are capable of in stock form.
Once again, no one compared a VG turbo vs fix geometry. We're comparing a 200 vs 300-320 hp highway spec ISB, which both have VG turbines.
Based on this setup, the 200hp version always have lower EGT, IAT, ECT, and piston / exhaust valve temp (based on lower EGT). Agree? Therefore, the 200hp engine lasts longer.
Also, there is no magical hp "limit" of an engine assembly. Everything is on an inverse curve - the higher the hp, the lower the lifespan, up to the absolutely breaking point (represented by the metal's UTS @ that working temperature). You can't say "an ISB has a working limit of 750hp", metallurgical fatigue limit doesn't work that way.
Okay, well then back up your statements because all I am seeing is a bunch of assumptions based on nothing.........
Re-read my writing instead of trying so hard to prove me wrong. I'm using logic based on engineering. Not once did I say "I say so because I've worked at XXX for XX years".
Remember, we're all trying to learn here, not to say who's right who's wrong...
