I think it depends on the year of the truck your looking at. If its 14 or 15 and even maybe the 13, not sure on that year because they changed the frame on the 13 or 14, then I'd go with the setup from Ram if its available after market. I had a 12 that I installed the Reese elite setup in, wasn't bad at all to install but now my 15 has the factory puck system in it and it uses a much bigger footprint than the Reese so I feel it spreads the weight out better. If the system is available from Ram then have them install it if you don't feel you want to mess with it.
