sjturbo's avatar
sjturbo
Ram recommended tire pressure
I just acquired a 2012 Ram 3500 H.O.. Sticker for rear tire pressure states 45lb for light load and 65lb for heavy load. I am used to going 80lb for my old F250 2500. At 65lb the tires seem to squat a bit. Anyone have this truck and can offer suggestion?
    DRW or SRW ?
    17" or 18" or 20" ?
    What tire size and load range ?
    Are they the OEM tires ?
    Makes a difference.
  • Who would know better than the engineers that designed the truck? I follow the numbers on the door post sticker.
    B.O.
  • My 2014 Ram 3500 door sticker says 80psi on the front steers, and 65psi on the rear duals. Ive done fine with pulling.
  • donn0128 wrote:
    Towing I run my dually tires at 80. Anything less reduces their load carrying capacity.
    So do you run over 9,750# on your 4 tires? That load only requires 65psi to more than meet that load with 4 tires. Running full psi is NOT always the best option.
  • Towing I run my dually tires at 80. Anything less reduces their load carrying capacity.
