jonmad's avatar
jonmad
Ram slide question.
Should rams on super slide be equally spaced? Mine has the rear slide about 1 foot from the rear and the other is about 4 feet from the front. Seams to work okay but comes in slightly angled. If anyone has a similar setup could you tell me if there have been any problems with it?
  • There is a timing shaft that is geared to each ram to keep it moveing straight
  • Rams are placed:
    Where there is room to locate them
    As needed for weight carrying provided there is room
    Where they can be located
    Overthinking it........
    Not going to be moved/relocated as they are where they are based on above :B
  • Even with the same mechanisms, each trailers slides have their own compromises. Each and every adjustment may not be exact, but trying to make one exact, may just make another not align as well. If it works good, I'd not mess with it, or have a very competent tech take a look at it, to get his opinion.
    You don't see a lot of response to slide adjust questions, due to one persons fix not being a fix for all.
    Jerry
  • Shouldn't make any difference where they are placed as long as they push evenly.
    In a perfect world, Everything wouldn't be.Yogi Berra
