agesilaus's avatar
agesilaus
Explorer III
May 21, 2022
RAM spare tire tool
Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
  • Fisherman wrote:
    Back to the question of needing a "key" to lower the spare, not on mine. One of the 4 sections of rod that get connected have a 5 sided open end that engages the stud on the crank mechanism.
    The one for the Ram is a square that is about 1/2".
  • Oiling the cable does nothing. The cable pulley is sandwiched between 2 steel plates. The shaft sticks in the plates. This is where you need lube.
  • I had a cable break while towing my fifth wheel, got lucky and didn’t break anything on the trailer. Inspect carefully!
  • I had a oh chit moment when I recently tried to lower my spare tire, but couldn't get the long handle to engage the rotating gear box to lower my spare. Needless to say, I need to go back and figure this out before I need it on the side of the road with a flat tire.
    Post that again when you see one looking like it's been in Salt Lake for 2 years. But your additional thought is a good one.
    ZACTLY, I just lowered my Dad's spare to change out the rear shocks and it's square for sure on his 14 3500 RAM.
  • I got a Dorman spare tool kit, there was a 30 inch extension rod but the shipping time was too long. I'll crank the spare down today or tomorrow and lube everything. Thanks for the replies
    Dorman tool
    Nice how you assumed I had no idea what rust is. You must be a joy to work with.
  • ^Oh fer fcks sake, guy asked about getting a spare tire tool and you’re arguing about whether the sky is blue….I’d say grow up but you’re probably both eligible for AARP and maybe SSI.
