richclover's avatar
richclover
Ram suspension problem
2018 Ram 2500 Tradesman, Cummins. Towed the camper to Mesquite, NV, and noticed a persistent steering pull to the right. I blamed it on the slope of I-15 and, maybe, the crosswind working on the camper.
But, driving home without the camper the same thing happened.
Off to the local Big O tire shop. Alignment was very close to correct and after adjustment, the truck still pulled right. Wheels rotated front to back, then left front to right front... No change. Brakes checked, no dragging brake.
But wait... I noticed the truck looked to be not level sitting in the garage. The right front wheel well measured about 2” lower than the left. Right rear is about 1 1/2” lower than the left.
Measurements confirmed by the local dealer today. No reason found yet. Confirmed no broken springs, coil all around. Shocks are okay. Ball joints okay.
10,000 miles on the truck...
Has anyone heard of a similar problem?
  • Recently read about a RAM that was doing the same thing. Turned out the allignment shop, in an effort to stop the live axle suspension from pulling away from the crown in the road, had turned the caster adjusters on either side completley different directions which is a total no-no.
  • Sounds like weak springs. Get them all replaced not just the low side.
    Still in warranty? You will have to fight to get them to cover all four springs
