CampingN_C_'s avatar
CampingN_C_
Ram "trailer disconnected" message.
While going to the track yesterday the warning message popped up saying the trailer was disconnected. It wasn't as I still had all my lights working. As I drove it connected and disconnected several times.
Trailer is brand new (not that it matters).
I've done some searching on others forums and answers are scattered from truck issues to trailer issues. It's raining for the next couple days so I'm stuck 'laptop troubleshooting'.
Have any of you guys had this issue with a newer Ram ?
Something else, possibly unrelated, but just thought of.
When I went to hook up the camper several months ago after sitting for a while the battery was to weak to work the jack. I plugged it in to the truck and still nothing. I lowered it on the ball, got a spark and it worked. It shouldn't pull 100% of it's ground through the ball, leaving me to think the truck ground is weak.
Thoughts ?
  • We had that on our truck. Turned out that three of the four magnets had burned up and the emergency pulled fried its self as well.
    rewired everything and it was fine..... still traded it in for a new RV
  • I've had that message appear in both a Chevy and a Ford truck that I've towed with. For me, it was the 7 pin plug. They don't really make a real tight connection. I solved my problem by adding a little shim where the tab is to keep the plug in tight.
  • Had the same problem and found this. Turned out it was right on.http://www.airforums.com/forums/f463/2011-dodge-ram-trailer-brake-disconnected-problem-79165.html
  • Trailer Disconnected message happens due to loss of continuity in the brake circuit, either by disconnect, bad connection, or broken wire. I would look into the brake circuit, or, as you mention, the ground.
