eHoefler wrote:
On my 2014 3500 dually Ram, I run 40psi in the rear for towing my light trailers and 80psi when the fifth wheel is attached, no problems.
In your case, vehicles over 10,000 GVWR are not required to have a TPMS system (1-ton and up). So RAM decided to just make it a "Tire Pressure Information System" (TPIS). It will never give you a warning, but it still monitors air pressure so you can check it every so often. That is on 2014 and up. For 2013, I don't know, but I know I don't have a TPMS because I don't get alerts either. I run 60/55.
I have heard of other pressures being set by the dealer, I believe there is a good post on Cumminsforum that details the exact step as most dealers don't know how to properly re-program the pressure (or it could be for tire size, I don't remember off the top of my head). But doing a search there can certainly help.
