Bedlam
Jul 25, 2016Moderator
You can run an Anderson connector with heavy gauge wire between your RV and truck for better charging. Having the higher amperage alternators will provide sufficient current without taxing the charge circuits in the truck. This is frequently done with truck campers, but can be done with trailers and fifth wheels too. The 7-pin power line is not much more than a trickle charge.
