Sweet tater that'd be awesome! How bout front window while you're at it? Lol
I got most of the plumbing wrapped up. Swapped tank from donor TC, plumbed pump with soft lines and installed 2 gallon expansion tank (that and soft pump lines my favorite two water mods in a camper!) and got a waste dump valve installed so gray can backup into black tank. New kitchen faucet installed since other one leaked. I need to get more pics. Electrical is all done. Furnace is next to install and gotta pull water heater to redo the tie down anchor there. Then to go over gas system and check it out. Then more cleaning and re-sealing on outside. I moved it from side yard to carport. It's a heavy SOB! Looks monstrous even on my big dodge dually!
