Gulfcoast wrote:
I just bought a clean 2006 Dodge 2500 with a 5.9 diesel.
I really want an exhaust brake on it, but I simply can't afford another $2000 right at this time.
Is there anywhere to buy a used one?
Any tips to save some $$$?
Thanks
Wish I would have seen this earlier! Your 06 can run an exhaust brake from the factory ecm with no aftermarket controller necessary. All you need is the pacbrake (brake only kit) and an air compressor setup.
Then all you have to do is follow these directions:
Pacbrake InstructionsFor the ecm wiring you need 2 of the Cummins pigtails (Cummins part number 3164263). Just follow the wiring diagram in the pacbrake instructions and you'll be good to go. The 06-07 ecm has all the parameters needed to run the brake, you just have to plug it into the ecm.
Next step is getting your transmission tuned for towing:
Https://www.mm3tuning.com
