Vulcanmars
Oct 24, 2018Explorer
Lots to look at on any used unit:
Pull up dinette cushions and check for water damage at outer corners. Same under bunk house sofa. Check outer slide seals/wipes, very poor quality rubber. Pull inspection cover under shower/tube and check for missing tub support which causes drain pipe to break and rot floor under tub. Asssume both door windows leak unless resealed by current owner. If original tires, replace all 5 asap. Assume you will need to re-caulk everything bolted to the exterior, they seem to ration it at the factory.
44,057 PostsLatest Activity: Mar 12, 2026
