Ian10965
Apr 28, 2018Explorer
What make and year is your trailer?
I'm trying to understand how the braces connect to the frame. It's hard to tell in the picture, but it looks like the yellow rail sits under or next to the actual RV frame. Is this part of a shock mount kit?
It looks like the center brace has a backing plates that surrounds the spring bracket to clamp the brace on to it.
The end braces look like they must use a separate bolt through a hole drilled in the side of the spring mount, since the brace sits above the shackle bolts.
Has this corrected the frame weakness completely regarding the spring mounts?
Thanks
Ian.
Thanks
Ian.
44,026 PostsLatest Activity: Jan 26, 2024
