cmack
Jun 29, 2014Explorer
A/C units generally do not take air from the outside and blow it inside unless it has a vent setting which is not the fan setting (auto a/c not included). Air is recycled within the space to be cooled. The air inlet inside is where you find the filter which filters (duh) the air prior to going through the blower and onto the evaporator coils which is the part that actually cools (or removes the heat from the air) and then out the vents. The outside condenser is air cooled via a fan. So yes, the outside air is kept separated from the inside air.
44,061 PostsLatest Activity: Apr 08, 2026
